Wrong part disposition from ACIS (.sat file) Abaqus/CAE
Hello everyone! I have a problem regarding the creation of an assembly in Abaqus/CAE 6.14-4. I generated a 3D model from AutoCAD 2019 end exported it as an ACIS (.sat) file. After I import all the parts into Abaqus, I try to create an assembly from the parts, but the result is as follows:
Spoiler:
As You can see, the plates and the bolts aren't in their correct (and original position), as they were in AutoCAD:
Spoiler:
How could i fix this problem?
RE: Wrong part disposition from ACIS (.sat file) Abaqus/CAE
You can use the tools available in Assembly module of Abaqus, like translation, rotation and so on. They allow you to manipulate the position of instances freely. With such a simple model it shouldn't take much time to fix it manually using aforementioned tools.
Can you try with a step file?
Thanks in advance for the answers! I preferred to manage the entire model in AutoCAD because i feel better in positioning precisely all the elements (and because I'm not expert yet of Abaqus).
For the .stp file, it's only compatible with AutoCAD Mechanical: unfortunately not my case.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
