Saturated salt brine friction losses
Hi All,
Can you please recommend a resource that will help me calculate the head ( friction) losses for a saturated salt (NaCl) brine pumped circuit. I can't seem to find any charts or correction factors that would give the friction losses or compare it to equivalent water flow.
I would need to pump the brine from the central saturator tank out to water pre-treatment skids and boiler feed water prep.
Is there a rule of thumb that can be used?
RE: Saturated salt brine friction losses
Just use the correct viscosity and density of the sol'n in the normal methods.
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
Roughness value for PE/PVC / other thermoplastic piping is much less than that for carbon steel lines. ξ = 0.0456mm for non corroded CS piping and 0.005mm for plastic piping.
Tank you
Thanks Iomcube
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - A Guide to 3D Printing Materials
When it comes to using an FDM 3D printer effectively and efficiently, choosing the right material at the right time is essential. This 3D Printing Materials Guide will help give you and your team a basic understanding of some FDM 3D printing polymers and composites, their strengths and weaknesses, and when to use them. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
