CATIA Macro Slows Down After Some Executions
Eren C.
Aerospace
TR
I am trying to write a code to create points. These points will be placed on the all edges of a Pad (in the middle of edges).
In first executions, it takes less than 1 seconds to finish one pad. However, after some executions, it takes more than 4 seconds for a pad.
Could you please help me what I am missing here? Thanks a lot.
Here is my code: (I think the line bolded is the issue here. I am calculating the time over this line. At first, it takes nearly 0 seconds. After that, it takes nearly 0.5 seconds to execute this line.)
Code:
Sub CATMain()
Dim Selection
Dim InputObjectType(0)
Set Part1 = CATIA.ActiveDocument.Part
Set Selection = CATIA.ActiveDocument.Selection
Set HSF = Part1.HybridShapeFactory
Selection.Clear
InputObjectType(0) = "AnyObject"
Status = Selection.SelectElement3(InputObjectType, "Select a Pad", False, CATMultiSelTriggWhenUserValidatesSelection, False)
If Status = "Cancel" Then Exit Sub
Selection.Search ("Topology.CGMEdge,sel")
Part1.InWorkObject = Part1.Bodies.Item(Selection.Item2(1).Value.Parent.Parent.Parent.Name)
For i = 1 To Selection.Count
 [b]Set refPoints = HSF.AddNewPointOnCurveFromPercent(Selection.Item2(i).Value, 0.5,True)[/b]
Next
End Sub
