Alignment - Actual Offset
Hello All,
Can you please let me know what dies vendor trying to say with the term actual offset (.15 mm) when he has already given TIR (.05) for both vertical and horizontal.
FOR ENGINEERING PROFESSIONALS Contact USThanks. We have received your request and will respond promptly. Come Join Us!Are you an
*Eng-Tips's functionality depends on members receiving e-mail. By joining you are opting in to receive e-mail. Posting Guidelines |
RE: Alignment - Actual Offset
Walt
This is the new machine which is getting commissioned with vendor onboard.
Vendor was not able to answer when I asked for it.
Utlimately hes considering 0.15mm as offset(bottom reading).
i.e. both faces of the coupling are aligned in parallel with each other vertically and horizontally, but the centre point of the shafts are 0.15mm adrift?
I raised by query to the manufacturer , after some days he replied with Radial tolerance at the bottom (.2mm to .4mm)
He has simply multiplied .15+-.05 into 2 to get the bottom readings ((.2mm to .4mm).
Even with these readings I have little doubt.
