stamping the cover page
hey guys,
if i am stamping a section substitution report, and the report included the MTC from the manufacturer and other stuff, can i add a note under the stamp saying this :
"This is to certify that the geometrical properties of the proposed sections matches or exceeds the original section"
the purpose of this note is to specify that i only checked the geometrical properties.
knowing that the project is not in the US but the client is american and he is asking for a PE to STAMP the Report.
ôIf you don't build your dream someone will hire you to help build theirs.ö
Tony A. Gaskins Jr.
Tony A. Gaskins Jr.
RE: stamping the cover page
I have reviewed the geometric properties of the sections used. The geometric properties meet or exceed the properties of the sections originally proposed.
There is an implied certification there, but only in that the Owner or other who will be depending on the plans is assured that a licensed engineer did the design.
"Either the cover, title, index, or table of contents page, or first sheet of any report, specification, or other professional document prepared by a registrant or the registrant’s bona fide employee"
"If civil engineering specifications, calculations, and reports are required to be
signed and sealed or stamped and have multiple pages, the signature, seal or stamp, and date of
signing and sealing or stamping shall appear at a minimum on the title sheet, cover sheet, or
signature sheet."
Appendix 6
http://www.peo.on.ca/index.php/ci_id/22090/la_id/1...
Based on this statement, I'm assuming there's no actual law or jurisdiction requiring the stamp aside from your client's requirement. As such, I would infer that it is completely up to your client what they will accept. Your approach seems reasonable to me given what you've stated. You could either submit it to your client and see if you get any comments or response on the subject or inquire to them ahead of time if such a statement meets their expectations/requirements if not clearly defined.
Tony A. Gaskins Jr.
