I have the following problem: A pipe shall have a constant surface temperature, whereby it gets elevated (from mean sea level to 10km) such that the ambient temperature and the air density decrease. I need to know the rate of heat flux.
I tried to solve this problem by calculating the Prandtl, Rayleigh number and Nusselt number (Free convection & external flow). With the Nusselt Number I determined the convection coefficient. The formula Q=α×A×ΔT allowed me to obtain the rate of heat flow. With ΔT=Tsurface,pipe−Tambient, A being the surface area of the pipe and α the convection coefficient.
I calculated the Nusselt number the corresponding Q for different heights (in total 40), but not continuous because I did not know how to get height depending functions for viscosity, thermal conductivity etc.
Is Q now the rate of heat flow which I can apply so that the surface temperature of the pipe is not exceeded and is my approach correct?
