Balloon Auto-Fill
Balloon Auto-Fill
Balloon Auto-Fill
Is it possible to have a macro that when run, would allow me to click on a part in an assembly drawing, create a balloon and populate the text with a property I created in the part properties. ?
I'm struggling trying to find the code to point to a specific property.
any help would be appreciated.
thanks
Alan
RE: Balloon Auto-Fill
Hello, i think its possible, i have somewhere macro, it takes any part properties and fill header in drawing, in ur case it will be just to fill ballon. ALso that first part of code is here on forum.
https://www.eng-tips.com/viewthread.cfm?qid=448499
Thanks, I’ll give it a go :)
Tried the code but couldn't get it to work.
Does anyone know how catia shows the number of a part before it creates the balloon ?
Also I use catia start command to begin the balloon creation it doesn't actually put a balloon around the text, any ideas why ?
After you run Generate Numbers, the number appears in the Properties of each assembly component
Thanks jackk,
I have searched the net trying to find a snippet of code that pulls a parts parameters into a drawing but nothing seems to be out there.
Do you know if this is just one of them things that catia can't do. ?
The odd item that I have come across doesn't work.
ta
Alan
Hi, i am sry, i wasnt here for some time, its not that hard to take those parameters.
If you are in drawing just switch to the part u want to take parameters, take it, then switch back to the drawing and fill it.
I have one more idea, if you crate first ballons with part number, you can use that info to swith to the parts or open them, so u can tak ethat parameters you want.
Hi, thanks for the replies,
The method you mentioned is the one I'm using at the moment.
When you balloon a part it will auto fill with the part number, what I'm trying to find out is how does it find this number ?
If I could find the code it uses them maybe it's possible to have a macro that will autofill balloons with any part property you like.
Correct me if I am wrong, but before you run the balloons, you need to run the Generate Numbering command, which generates Instance Numbers in Part Properties
regards,
LWolf
Hi LWolf,
If you go to options / drafting / annotation & dress up / balloon creation
you can select either Numbers, Instance or Part number.
So my thinking is, if it knows the part number why can't it find a property inside that part ?
I could be barking up the wrong tree again & it might not be that simple.
cheers
alan
I probably didn't make myself clear when I first asked about this.
I don't want catia to auto-balloon an assembly as such.
I'm looking to create a macro that will create a single balloon that will contain a properties text instead of the part number.
clear as mud :/
i m not sure that's possible, but i m also interested how they do it, it must be smthg, i dont work a lot with 2D.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
