I am a fabricator looking for recommendations for a low pressure water hydraulic cylinder that can be connected to a municipal water supply (NYC- approximately 60 psi)
Im looking for something with a short stroke- ~3" max, piston diameter ~3/4", that can be used to apply clamping pressure in a work-holding jig. I am hoping to have a kind of quick-clamp that gets its clamping force from a connection to the plumbing in the building. This is an oddball application that in this case needs to be water-pressure activated.
I have had some difficulty in finding recommendations for such a low pressure water hydraulic cylinder. I would prefer not to build my own from scratch, and would rather have something off-the-shelf that can be connected and tested. The clamping jig would be cycled only a few times per day, so this does not need to be an extreme-duty part. Im looking for something light duty for the purposes of testing my workholding setup.
Can anyone recommend a suitable cylinder for this application?
Thank you in advance.
All the best,
mrb
All the best,
mrb
