Liquid nitrogen injection nozzle
I would like to know the velocity and other criteria to design a liquid nitrogen injection nozzle. This liquid nitrogen will be an intrusive quill inside a pipe where there will be hot nitrogen recycling, so the mix will be a medium temperure stream. This stream will cool down some equipment.
Any papers or info are welcome.
Thank you.
Dani
RE: Liquid nitrogen injection nozzle
Your statement leaves me with a lot of questions. I have used cryo fluid to cool a compressor with inter cooler issues, its not ideal.
First does your company have standards for cryogenic piping design? If not, CGA or EIGA are the best source for cryo work. Maybe ask your liquid Nitrogen Supplier for some data. There is a whole can of worms here....
If you are using US units, you can find the proprieties relative to water for flow characteristics, but that's assuming your not having mix phase flow by the time the fluid gets to the nozzle. This will cause vapor lock issues depending on system design, which will cause erratic cooling. To make this work best you will need sub cooled Nitrogen, well insulated pipe (maybe VJ pipe), appropriately designed pipe work and, the flow is steady. If you have this, the calculation is text book.
There are charts for flash of cyro fluids through nozzles depending on the delta P, this will give you an approximation of liquid carry over. From there you will have an idea of the mixing of your hot nitrogen with the remaining liquid to complete the vaporization.
Just to recap, the problem is pretty text book, however field application can be a challenge with mix phase flow. I don't know your application/budget but I ended up using a Valtek mark-one instead of a nozzle, and had two thermo couples which controlled the valve off a target temp.
White Paper – Your Construction ERP RFP Checklist
Selecting business software for a medium to enterprise-sized construction concern is extremely challenging in large part because most enterprise resource planning (ERP) suites originated in the world of repetitive manufacturing and are therefore a poor fit for a project and asset-centric business. However, midsize to large contractors need the predictable, auditable processes that ERP delivers. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
