Not a flat lander typically, but i have a coastal job with seasonal high water table. the site is farmland with a couple "sumps" where water infiltrates. Large storms accumulate and discharge to a right of way ditch. the design will create two interconnected ponds and the lower pond will discharge into a right of way ditch with no tailwater condition. the uphill pond is proposed in one of those sumps that has a water table about 1' below the surface and the lower pond has water at a depth of about 4'. i suspect if we install the stormline from bottom to top we'll essentially dewater the site eliminating the perched water and sending it to the dead pools of the two ponds or into the ditch.
is there any advice or reading out there about special bedding requirements or construction spec's unique to working in this scenario?
If you need advice on pipe installation review storm sewer installation procedures in your area. If you need advice on stormwater management pond design there are a lot of resources available from different jurisdications
Thank you for helping keep Eng-Tips Forums free from inappropriate posts. The Eng-Tips staff will check this out and take appropriate action.
This white paper provides a complete guide to enclosure thermal design, covering all the main points that need to be considered. If you are responsible for enclosure-level thermal design, Simcenter provides a range of thermal design software, allowing you to select a product that is an ideal fit with your company’s thermal design workflow and supply chain needs. Download Now
How much PLM is right for smaller manufacturers? Midsized companies need capabilities but have limited resources. In this eBook, Jim Brown, President of Tech-Clarity, takes you through getting started with the right PLM solution. Download Now
Airbus and Ralf Schlueter, Managing Director, of Flugzeug Union Süd (an Airbus subsidiary), have turned to additive manufacturing and digital design solutions to modernize the investment shipping case industry. They’ve submitted a patent application for an additive production process using BigRep large-format 3D printers. Download Now
As Best-in-Class electronics manufacturers move towards smart manufacturing, Industry 4.0, and Internet of Things-connected equipment in the plant, manufacturing execution systems (MES) are becoming more important than ever, because they enable real-time unification of electronics and mechanical production information. Download Now
RE: Design of Stormline in high water table
