I am modelling a piece of steel (typical structural steel) that will be heavily loaded in a variety of directions. I am using FEA to check the stress distribution of the part. I am checking Von Mises criteria for yielding, as compared to the yield stress as determined from a typical steel tensile coupon. Due to the complex nature of the loading, I would also like to check for the potential of brittle fracture due to high principle stress (even if there is no yielding). What value should I compare the max. principle stress to? The ultimate stress of a steel coupon? Is it possible to achieve brittle fracture in what is typically considered a "ductile" material?
Thanks.
J
Thanks.
J
