Self Teach - FEMAP
POPEYES
What is the best resource for an engineer to teach themselves FEMAP? It seems like a lot to get started with without a set of tutorials, or textbook that are structured for beginners.
youtube seems to be a favourite. There are plenty of courses and web training from Siemens. This assumes a knowledge of FEA, which you can get from plenty of primer texts.
I have a background in solid works simulation, but nothing seems to work in FEMAP like it does in an in-CAD FEM. FEMAP seems archaic and really not user friendly, perhaps I just need to get used to it. I’ve watched some YouTube videos, but I have t found anything for my application, which is a lot of structural modeling using shell elements.
ok, just trying to undertstand where you're coming from.
don't try PATRAN (if you think FeMap isn't user friendly). FeMap does definitely have quirks about how it does things. I haven't used SW.
I'd try Siemens courses.
Hi
If you look in the Femap installation on your hard drive you find a catalogue called pdf. In that there is a file called examples that consists of several step-by-step examples regarding modelling. In my experience, YouTube-examples can show you what you can do but often fails in how to do it. At least for a beginner.
You say that Femap seems arhaic and not very user friendly. From a certain point of view I can agree, it's not like the in-CAD solutions. But when I looked at Nastran-in-CAD from Autodesk due to the Autodesk bought the Nastran version I used, I switched software. My issue was that in-CAD was very limited in several areas. It "holds your hand" to hard. Femap, once you have learned it is much more flexible, in my opinion.
Good Luck
Thomas
