Ultrasound polyvinylchloride standoff deformation validation test
SteFan89
Bioengineer
GB
Hello
I am using a polyvinylchloride standoff for encapsulating the ultrasound probe while scanning.
In order, to measure its accuracy on deformation related to specific forces, I need to do a validation test to assess its accuracy in deformation under known volume.
In that essence, I am using different pin sizes (e.g. 2.5mm, 3.5mm, 5.0mm) in diameter and I apply force while compressing the standoff upon those pins. The standoff gets deformed. Less force, less deformation and the reverse.
I now have the data in an excel file. I need to estimate how, the pin size in the ultrasound image is deviating from the original pin size. For instance, if I measure the 2.5mm pin size, and I am able to measure 2.5 mm in the ultrasound image, then I can say that I have an ideal deformation of the standoff with no error at all.
I am confused of how to implement it. I am thinking of taking a small margin area in the ultrasound image where the pin peak is, and measure the maximum pin height that can be depicted in the ultrasound image. I'll do this procedure for several pixel columns and then I will calculate the standard deviation among the pixel columns. Finally, I will subtract the standard deviation from the original pin size to estimate the error.
Is my procedure correct? Is something that I miss, can you suggest me a better method?
Thank you
 https://files.engineering.com/getfile.aspx?folder=862fdd55-51aa-4c01-bcf9-dbc55a59776f&file=1ready.png
I'm getting only a vague idea of what you are doing, any chance you could post a picture or sketch of the setup, and where the deformation is occurring?
