API 650-AST bottom slope-upwards
Greetings!
I am working on an API650 storage tank,
The client insists on the bottom of the tank to be slopped upwards towards the center 1/120, but i’m very unfamiliar with this design since i have been designing all the storage tanks with bottom slopped downwards to the center.
So my question How would i design a drainage system for this type of tank, and how would it work?
Thank you in advance!
Detailing is a hobby,
RE: API 650-AST bottom slope-upwards
Is there a way to determine the number of sumps needed?
Plus the civil engineer of the client designed the concrete foundation as a disk slab under the tank and not not a beam ring. It is it possible to incorporate our sumps systems in such a foundation?
Putting one or more sumps in a slab foundation is not unusual. It is harder to retrofit a sump in a cured and hardened slab but it's just more work. You may want to use a shallow sump if the slab is thin.
In theory you only nee done location to draw off liquid a the lowest point, but in practice larger tanks need more as it is not possible to get a tank laser line flat once it's been built and tested.
So the civil engineer has provided a single thickness slab under the entire tank??
He clearly has more money than most tank builders...
You can incorporate sumps in any foundation but just need to detail them beforehand.
Very helpful!
