Procedure for slip-critical connection preparation
Hi everyone, is there anyone who can list in a few points the procedure a steel contractor should follow to get a proper slip-critical connection, including proper bolt tightening and all inspections..? I understand when slip-critical connections shall be specified, Code of Standard Practice is clear on that and I understand the difference between sc and bearing type, that plates shall be clean of paint etc. it is just not enough - I have a steel contractor who I work with, I do engineering and shop drawings for him, and he's never done slip critical connections and I do not have enough knowledge to explain him step by step what needs to be done to get a slip critical connection from fabrication point of view and what shall be inspected and when prior to steel assembly. I'd appreciate your help.
eBook - Efficient and Effective Production Support with 3D Printed Jigs and Fixtures
Jigs and fixtures offer manufacturers a reliable process for delivering accurate, high-quality outcomes, whether for a specific part or feature, or for consistency across multiples of parts. Although the methodologies and materials for producing jigs and fixtures have evolved beyond the conventional metal tooling of years past, their position as a manufacturing staple remains constant due to the benefits they offer. Download Now
Overcoming Cutting Tool Challenges in Aerospace Machining
Aerospace manufacturing has always been on the cutting edge, from materials to production techniques. However, these two aspects of aerospace machining can conflict, as manufacturers strive to maintain machining efficiency with new materials by using new methods and cutting tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
