fracture_point
The NBCC (Canadian building code) allows us to reduce the base shear by multiplying by a factor of IE/RDRO. The code then specifies that for deflections, the values should be multiplied by RDRO/IE. My question is, should we be multiplying the reduced base shear values by this factor, to bring the deflections back up to an elastic base shear, or should we be multiplying deflections using the original elastic base shear, to increase them (by approximately 2 for RdRo = 1.5 x 1.3).
I think the latter, as this increase in deflections captures the deflections possible due to the inelastic behaviour expected in an earthquake. My colleague feels that it should be the former, where we are increased the reduced base shear back up to the original elastic base shear for deflections.
