Is it possible to have a journal that will copy an object to another layer and rotate the copied object in a specific way? I know how to copy an object, but I'm not sure how to move it/rotate it.
If you know what body to move and how you want it moved, a journal can be written to do it. I'd suggest starting by recording a journal while using the "move object" command (with the 'copy' option).
Is this related to your other thread?
thread561-429164
