Contact US
Valve data sheet not found
I have an installed manual valve at site, but no data sheet for it. its an old valve (20yrs) and the manufacturer still exists.
Is there a way to retrieve data about the valve?
Thank you
RE: Valve data sheet not found
If there's still a nameplate on the valve they typically have a serial or model code which should be able tell you everything you want to know.
Sometimes the model number cast into the valve body so you at least have that information. Otherwise take a picture of it and ask your local rep.
What kind of data are you looking for?
You can already gather a lot of information using only the norm your valve has been designed with. Maybe you can post a picture here.
Hopefully if the nameplate hasn't been painted over the last 20 years, you can ask your local Rep, RVAMeche is right.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
