CT = Constant Torque maybe?
I agree with the others, we don’t know enough about that motor and the real people to ask regarding inverter operation is the motor mfr.
Or, you could invest in what’s called a “sine wave filter” to go on the output side of the VFD, then add “shaft grounding bushings” to the motor as well as a separately powered cooling fan, that way even if it is not meant for VFD operations it will survive longer. You may find though that all of those measures will end up exceeding the cost of just replacing the motor with one designed for inverter operation.
