Dear Members,
I have a heat exchanger to heat Natural Gas (tube side) for combustion in 2 drum dryers. LP steam at 350kPa is on shell side. The NG inlet temp is 12 F and outlet is 68 F. I need to know if there is a need for a PSV (thermal case) on the tube side if the NG is blocked in. Most of the literature and API 520/521 refer to need for PSV (thermal case) for "liquids" that are blocked since liquids are incompressible.
