Queries about abaqus command line and steps with respect to load and unload situation
Greetings,
a) Command line:
When I try to enter "abaqus job=Triangular_fibre suspend" into command line in Abaqus CAE, it gives a syntax error. When I try the same command in cmd or abaqus command the error says that it could, not determine the client ID of the job request albeit after changing the directory as well!
b) Just a general question regarding a general load and unload situation; correct my analogy if I am wrong:
Say I decide to model a dynamic load in which the load is held at x magnitude for a time and then the the model is unloaded completely for b time, then I shall model in step manager as follows: make TWO STEP TIMES: one with a time period and one with b time period (i am talking here with with exclusion of initial step). The second of the two steps will have no loading case whilst the first one will have a loading case.
RE: Queries about abaqus command line and steps with respect to load and unload situation
a) So you want to suspend a job ? Try this: "abaqus suspend job=job_name" (switch places of these two parts). Also make sure that the job name is correct and open CMD in the folder where job files are. It's also possible that there's a problem with default "abaqus" command. Try abqXXXX (where XXXX is Abaqus version - for example 2018) instead.
b) You can use two steps for that but why not to define such amplitude curve that the whole load history will be included and use it in one step ?
Thanks for your help. I am using two steps as i am running short on time on my disso and i can't be bother waiting days more for results to come again.
Thanks anyway
If you want to speed up your analysis because you’re short on time then I recommend trying some of the tricks listed in this thread:
https://www.eng-tips.com/viewthread.cfm?qid=449985
Parallelization is probably the most important one here. Apart from mesh density reduction, of course.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - A Guide to 3D Printing Materials
When it comes to using an FDM 3D printer effectively and efficiently, choosing the right material at the right time is essential. This 3D Printing Materials Guide will help give you and your team a basic understanding of some FDM 3D printing polymers and composites, their strengths and weaknesses, and when to use them. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
