Modify Part Script to Work At Assembly
jzecha
Aerospace
Can somebody please help me modify this code which adds 3 new Parameters to a part to work at the assembly level and adds these parameters to every part and product?
Code:
Language="VBSCRIPT"
Sub CATMain()
Dim partDocument1 As Document
Set partDocument1 = CATIA.ActiveDocument
Dim product1 As CATBaseDispatch
Set product1 = partDocument1.GetItem("")
Dim parameters1 As Parameters
Set parameters1 = product1.UserRefProperties
Dim strParam1 As StrParam
Set strParam1 = parameters1.CreateString("DETAIL NUMBER", "")
strParam1.ValuateFromString ""
Dim parameters2 As Parameters
Set parameters2 = product1.UserRefProperties
Dim strParam2 As StrParam
Set strParam2 = parameters2.CreateString("MATERIAL", "")
strParam2.ValuateFromString ""
Dim parameters3 As Parameters
Set parameters3 = product1.UserRefProperties
Dim strParam3 As StrParam
Set strParam3 = parameters3.CreateString("STOCK SIZE", "")
strParam3.ValuateFromString ""
End Sub
you just need too use multiple selection, for those parts from assembly and then run for loop to set these parameters.
You need to define "partDocument1" using selection.
Instead of using a partdocument object, use the activedocument object. Activedocument can contain parts, drawings, or assemblies. Not all functions behave the same on all types of objects though.
You are also will want to run through a loop to assign the parameters to each subassy and subproduct while walking down your assembly structure step by step. You will need to use the appropriate "collectors" to do that.
-or-
Search for the objects using a criteria and then assign your parameters to each object in the items that were selected by the search. Search syntax is really powerful.
Here is an example of hiding every geometric set in every part in an assembly of arbitrarily large size. Three lines of code. The heavy lifting happens on the first line. You could probably modify this to add your parameters to every part and assembly. Use the GUI search function to figure out your search syntax.
CATIA.ActiveDocument.Selection.Search "'Generative Shape Design'.'Geometrical Set'.Visibility=Shown, all"
CATIA.ActiveDocument.Selection.VisProperties.SetShow catVisPropertyNoShowAttr
CATIA.ActiveDocument.Selection.Clear
BTW, I am a hack macro programmer. Don't listen to me if someone better comes along.
IMHO selection performs badly on large models.
I've utilized recursion...
Sub CATMain()
Dim ActiveModel
Set ActiveModel = CATIA.ActiveDocument
ActiveModel.Product.ApplyWorkMode DEFAULT_MODE
Dim products1 'As Products
Set products1 = ActiveModel.Product.Products
Dim k As Integer
Dim FullPath As String
For k = 1 To products1.Count
FullPath = products1.item(k).ReferenceProduct.Parent.FullName
If Right(FullPath, 7) = "Product" Then
Call DoTheJob(products1.item(k).ReferenceProduct)
Call Sub_Product(products1.item(k))​
ElseIf Right(FullPath, 4) = "Part" Then
Call DoTheJob(products1.item(k).ReferenceProduct)​
End If​
Next
End Sub
Sub Sub_Product(ActiveModel)
Dim oProducts
Set oProducts = ActiveModel.Products
Dim oProduct
Dim k As Integer
For k = 1 To oProducts.Count
FullPath = oProducts.item(k).ReferenceProduct.Parent.FullName
Call DoTheJob(oProducts.item(k).ReferenceProduct)
Call Sub_Product(oProducts.item(k))​
Call DoTheJob(oProducts.item(k).ReferenceProduct)​
End If​
Next
End Sub
Sub DoTheJob(oProductRefProduct)
Dim UserRefParams As Parameters
Set UserRefParams = oProductRefProduct.UserRefProperties
Dim DetailNum As StrParam
Set DetailNum = UserRefParams.CreateString("DETAIL NUMBER", "")
DetailNum.ValuateFromString ""
Dim Mtrl As StrParam
Set Mtrl = UserRefParams.CreateString("MATERIAL", "")
Mtrl.ValuateFromString ""
Dim StockSize As StrParam
Set StockSize = UserRefParams.CreateString("STOCK SIZE", "")
StockSize.ValuateFromString ""
End Sub
regards,
LWolf
