Positioning of Fixed and Sliding Saddles for a Horizontal Shell & Tube Heat Exchanger
3
I would like to know, what is the basis of positioning the Fixed and Sliding saddles(which side which saddle) for a horizontal Shell & Tube Heat Exchanger.
RE: Positioning of Fixed and Sliding Saddles for a Horizontal Shell & Tube Heat Exchanger
DK44, normally you would locate the fixed support at the end of the exchanger having the most process nozzles. For a multipass tubeside arrangement this will nearly always be at the inlet channel end. For single pass tubeside arrangements it is less clear.
Ideally the buyer will either specify or review and confirm, since typically only the buyer has any knowledge of the arrangement of the attached piping.
Mike
It really depends on how the attached piping is configured but generally you want the sliding/slotted saddle support located at the front (channel) end of the exchanger. This is because the piping that's attached to the exchanger is typically anchored beyond the back end of the exchanger, so when the equipment heats up the thermal displacement for both the exchanger and the attached piping will be in the same direction, thereby producing less stress than if they thermal displaced in opposite directions.
-Christine
Christine74, kind of opposite my experience, but illustrates my point about only the buyer knowing :)
Oh I agree, probably 90% of heat exchangers out there are anchored incorrectly with the fixed support near the front channel. This is probably due to the fact that 1) the location of the the slotted saddle support usually isn't specified by the buyer, and 2) the piping engineer didn't review the exchanger G.A. drawing or he/she just assumed that there must be a good reason why the manufacturer chose to use the front saddle support as the anchor point.
-Christine
One reason is: For units with removable tube bundles, supports should be designed to withstand a pulling
force equal to 1-112 times the weight of the tube bundle.
r6155
Sorry, I said "....force equal to 1-1/2 times the weight of the tube bundle".
See TEMA
r6155
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Research Report - What’s the State of Nonlinear Simulation?
Simulation is an increasingly valuable tool across the product design workflow, but not all simulations are equal. We set out to determine how engineers and product designers make use of specialized analyses, how they incorporate nonlinear simulation into their work and how they rate the available software. Download Now
White Paper – Data Security and Know-How Protection
Our data is constantly exposed to the danger of being intercepted or stolen as it wends its way over global data networks. Data security measures and measures for protecting intellectual property should not, however, first be implemented when data is exchanged – companies must lay the foundation for these measures within their own organization. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
