Contact US
Red brass w/ sulphur content
Hi!
hope someone used to work with fuels can give me a hand. The fuel has a maximum of 0.1% of sulphur content in mass, according to its data sheet. In addition, its copper corrosion class is 1A in ASTM D130 test.
May a red brass housing valve be suitable for this fuel?
Thank you!
RE: Red brass w/ sulphur content
you're fine as long as it is not acidic, low velocity flows, low pressure drop, and room temperatures. The stem seal material needs to be checked for compatibility otherwise you'll have leakage problems.
If you are in a chem plant, steel or stainless steel....
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
