Constraints in drawing.
I can draw a line in the Main View of a DrawingSheet.
Now I can't figure out [using VB(A)] how to:
1. Apply horizontal constraint to this line?
2. Draw line vertical to this line such that end point of the first line is constrained to the start point of the second line.
3. Draw a (third) line parallel to the first line from the end point of the second line.
My aim is that if I select any line, all three lines should be automatically selected.
A. If I move any one line, other two lines should also move by exactly the same amount.
B. If I delete any one line, all three lines should get deleted.
In short, I am trying to emulate a pline in AutoCAD.
Any hints are welcome.
RE: Constraints in drawing.
1. Create a line; with MB3 select "Horizontal"
2. Create another line, using the end point of the first line; with MB3 select "Vertical"
3. Create another line, parallel to the first line from the end point of the second line(Catia will "suggest" a "parallel" constrain for you......
A. You may select all lines by:MB3/Auto Search
B. If you want to move all the lines, you need to give them dimensions
CAD 2015
Thanks but I want to do it using VB(A). Nothing is recorded in Macro.
Sorry, I am not such fancy.
I always use the simple stuff.
Good lock!
bigsmile
CAD 2015
I am little bit confused as I don't see the application of such a code.
I would say that maybe you could create a detail and inside you could create whatever you wantcomputing the points of lines using some basic algebra.
You would be able to move the details as you need in the ned.
You can have a look into Constraints collection and Constraint object in V5 automation reference.
Tesak
http://scripts4all.eu/txtoncurve/ - Text along a curve for Catia V5
eBook - Efficient and Effective Production Support with 3D Printed Jigs and Fixtures
Jigs and fixtures offer manufacturers a reliable process for delivering accurate, high-quality outcomes, whether for a specific part or feature, or for consistency across multiples of parts. Although the methodologies and materials for producing jigs and fixtures have evolved beyond the conventional metal tooling of years past, their position as a manufacturing staple remains constant due to the benefits they offer. Download Now
Overcoming Cutting Tool Challenges in Aerospace Machining
Aerospace manufacturing has always been on the cutting edge, from materials to production techniques. However, these two aspects of aerospace machining can conflict, as manufacturers strive to maintain machining efficiency with new materials by using new methods and cutting tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
