Electrical substation design and (failure) calculation of its elements
Hello.
I often need to calculate the efforts coming from short circuits in the substation. For the moment I have had to only calculate the efforts at the attachment points of the insulators, so only a simple model was needed (insulators + wires), so I had been using SAMCEF. However the program itself seems quite rough around the edges. So I was wondering, what are other 3d modelling/simulation/calculation programs, that would allow me to model a structure in a substation + calculate and simulate the efforts coming from short circuit in order to know whether my structure would fail (break, bend etc) or not.
Thank you in advance.
Kaisa
eBook - Mastering Tolerances for Machined Parts
When making CNC machined parts, mastering tolerances can be challenging. Are general tolerances good enough? When does it make sense to call out for tighter tolerances? Do you need a better understanding of fits, datums, or GD&T? Learn about these topics and more in Xometry's new e-book. Download Now
eBook – How to Choose the Correct Corrosion Testing Method
When designing a metal component, engineers have to consider how susceptible certain alloys are to corrosion in the final product’s operating environment. In a recent study by NACE (National Association of Corrosion Engineers), it was estimated that the direct and indirect costs of corrosion in the United States is approximately 6.2% of the GDP. In 2016, that cost exceeded $1 trillion dollars for the first time. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
