Design of geogrid reinforced earth wall for highway embankment
For the design of geogrid reinforced earth walls, the maximum vertical spacing of geogrids is limited to 800mm in FHWA/AASHTO. There is no such limitations in BS code 8006-1:2010.When the design is carried out for reinforced earth structure with gabion box facing and secondary reinforcement using BS Code, the external, internal and global stability criteria are fullfilled even if the vertical spacing of primary reinforcement is 2m at upper levels.
What is the basis for limiting the maximum vertical spacing to 800mm in AASHTO?
RE: Design of geogrid reinforced earth wall for highway embankment
Is this for a wall or reinforced embankment?
This is for wall MSEW.
I can't say for sure, but in my mind the maximum limit is to prevent something "strange" from happening between grid layers. In an MSE wall your are 'assuming' that the geogrid is going to engage the entire soil mass to prevent sliding, pull-out etc. We make some pretty simplifying assumptions regarding the stress distributions of the lateral soil pressure and these maximums (I beleive) are meant to ensure that things behave the way we assume.
If I was to go 6m between grid I would want to be very comfortable in my soil design values (long term conditions and short term).
I know this is easier said than done but, these type of walls are cheap, and very durable. However, they are very difficult to repair. Normally you just tear dwon and replace. I always feel like a little extra grid is insurance against a large rain event or something out of the ordinary.
But I get it, when you have a contractor asking "is it really neccesary" it is nice to have something to fall back on and say "yes, it is".
There might be better answers out there though. Most likely "that is the range of our testing".
EIT
www.HowToEngineer.com
Well stated.
White Paper – Your Construction ERP RFP Checklist
Selecting business software for a medium to enterprise-sized construction concern is extremely challenging in large part because most enterprise resource planning (ERP) suites originated in the world of repetitive manufacturing and are therefore a poor fit for a project and asset-centric business. However, midsize to large contractors need the predictable, auditable processes that ERP delivers. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
