Reuger pressure gauge selection
helpyou
Automotive
QA
HI
I have two questions please
1. I have five reuger pressure gauges to choose from, minor differences, but range is same. May be they 'll all work. how to choose? application is in a corrosive envirnoment, range 0-10 bar, process temperature -161 C.
2. in pressure gauge details, process fluid temperature range is not mentioned (range in which gauge can operate and not fail). Is this normal? I checked in Reuger manual, it says process temperature max 100 C, but doesnot say minimum Temp.
Thank you
Take a look at the latter part of Ashcroft’s app note on using gauges at cryogenic temperatures - they recomment capillary tubing to allow the desdhead capillary volume to warm to ambient.
pip_ash_pi_21d_gauge_general-info.pdf
