Valves stem material
could you please advise if we can use bar material in the valves stem fabrication ? , and whats the section in the code which covers this point if applicable .
FOR ENGINEERING PROFESSIONALS Contact USThanks. We have received your request and will respond promptly. Come Join Us!Are you an
*Eng-Tips's functionality depends on members receiving e-mail. By joining you are opting in to receive e-mail. Posting Guidelines |
RE: Valves stem material
17-4PH in sour application exhibit corrosion cracking thus not advised as per standard (If I am not mistaken API 6D)
MR
https://nosuchvalve.com
All valves will last for years, except the ones that were poorly manufactured; are still wrongly operated and or were wrongly selected
http://www.eng-tips.com/faqs.cfm?&rat1=2&f...
Danlaps answer would probably cover your question, but a lot is then assumed: producing to a market and applications best covered by ASME (US) standard.
The general answer is simply 'yes'.
