Contact US
Vessel Mounted Multistage Ethylene Transfer Pump- Cryogenic Sevice
We are currently looking for a possible Vendor to replace the existing Ethylene Transfer Pumps that we have at site. The old pumps were not so reliable and we end up servicing it every now and then. Thus we are exploring the possibility of sourcing the pumps from another Vendor. The operation is at negative temperature (Operating Temp. : -55DegC )(Design Temp :-104 DegC @ 0.0 kg/cm2g). The existing pump is a vertical multistage(20 stgs) vessel mounted submerged motor pump (no mechanical seal , motor is submerged with process liquid together with the pump stages).
Other details of the pumps that we are looking for are :
Fluid : Ethylene
Flowrate : 512 m3/hr
Suction Pressure : 22.9 kg/cm2g
Differential Pressure : 107.7 kg/cm2
NPSHA= 10 Meters
S.G.=0.436
Vapor Pressure : 23.4 kg/cm2a
Viscosity : 0.06 cP
I have come across three possible Vendors that could provide me with a suitable pump model under their portfolio namely:
1.Ebarra Cryo
2.Nikkiso Cryo
3.Shinko Ind. Ltd
Is there any other Vendor that you feel might have a suitable model for our service requirement. Please advise if you have any names in mind.
Tilas
RE: Vessel Mounted Multistage Ethylene Transfer Pump- Cryogenic Sevice
Suggestion www.framo.com worldwide pumping cargo solutions, factory in Norway
Thanks Gerhardl smile
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
