Contact US
Steam coil for heating-recommendations
I am designing an HFO tank,
Now as you might all know that the HFO needs to be kept at 50C for it to stay in a good state of flowing,
I am calculating the heat loss from the tank,
There is some things that confuses me,
1-how can i calculate the heat loss from the natural vent?
2-how can i estimate the heat loss from the nozzles?
3- is there any design standard that goes through all the estimated calculation?
I am currently using the ABC chemicals methods of estimating the overall heat loss (nozzles and natural vent are excluded) how ever data showed that its accurate.
4-any standard that can guide me through the designing of the steam heating coil?
Best of regards,
Detailing is a hobby,
RE: Steam coil for heating-recommendations
If you are being thorough, evaluate the heat loss through each surface - liquid surface, tank bottom, shell, fixed roof and floating roof if there is one. Loss through the shell can be further separated into loss above the liquid level and below the liquid level. Each loss quantity may have several mechanisms - conduction, convection and radiation. Even when done casually, there are many factors that come into play for each so you have to know the properties of the liquid as well as the local meteorological conditions (temperature, insolation, wind, etc) everything about your tank and of course the insulation. From my experience (on mostly large tanks), loss through a single nozzle is overwhelmed by the overall losses through the tank shell but they can be calculated in a similar fashion as the tank shell.
Designing heating coils is rather simple after you know the heat balance. You need to know the characteristics of the (probably fin-tube) heaters, your steam properties and the liquid properties. That mostly gets you the footage of coil needed. Design and locate the coil packs with slope for condensate return, to provide good coverage and to create convective swirls that don't interfere with each other. Coordinate with fill, suction and recirculation piping, air sparging and any blending equipment.
For a quick and most likely successful installation, engage your coil vendor to do the calculations for you. Ask for and follow their recommendations to avoid coking.
My opinion only - remember - you read it on the World's Wild Web !!!
@IFRs i was hoping you would answer!
Thank you that’s very helpful!
And also when you said “locate the coil packs with slope”, did you mean that the coil should be helical downward attached on the tank shell?
Can you recommend any book?
Jay - I only meant that the steam inlet to the tank should be higher than the condensate outlet for each coil, to promote flow of both. I usually see fin-tube coils in packs that start high and end up lower. Then the condensate line runs at a slope to the tank shell. Also, make sure you have allowed for thermal expansion in the piping running to the coils - a 90 degree angle with some length on both legs really helps. I'm not aware of a book on the subject but I'm sure Google could find some. For vendors in the USA, try American Heating, Heatec, Ryan Process Equipment, Armstrong-Hunt, RW Holland - there are tons of them and they do this for a living.
i'm going to check them out!
Thank you again @IFRs
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
