I'm in the process of putting together a maintenance plan for the maintenance section of an operating manual for a machine build. So far I've been going trough manufacturers documentation and taking data from this or referring the customer to the document. i'd like to be able to give more accurate data for bearing replacement. This is not proving easy however. we have purchased most of our OTS parts from Misumi (a great supplier by the way) but I cannot find any info on their webite in terms of the expected lifetimes of these bearings.
Bearing w/Housing, BGMW6902ZZ-50 is one such part that uses an NSK 6902 bearing. Unfortunately I an't find any info on the lifetime of this bearing online. Could anyone post a link to where I can find bearing reliability data/lifetimes? This is about as close as I can get to finding out more. Note that the zoomed in image is not the bearing I'm referring to, that's a linear bearing which I'm also trying to figure out maintenance info for.
Thanks.
Thanks.
