Centrifugal pumps - 2 questions
Hi everyone from Croatia.
This is my 1st post so I hope that dumb questions are allowed for newbies :)
1. Centrifugal pumps are turn on with closed discharge valves - why?
I have 2 potential explanations:
- if it is a point of lowest engaged power, especialy having in mind that starting current is 2-3x higher than nominal, and there is less load on wires, instalation etc... If power = pressure x flow -> when the outlet valve is closed, there is a very small flow trough relief valve or a gap ring (ring between case and rotor) -> as a result power is low.
- starting with closed valve will produce high pressure for instant cooling and lubrication of mechanical or seal with packing
2. why simering seal cannot be find on centrifugal pumps (what is a downside comparing to machanical or seal with packing)?
THX
THX
RE: Centrifugal pumps - 2 questions
Leaving a small leak around the valve will prevent seal failure from overheating with regard to a blocked off pump churning a little water. Even a small leak is usually more than adequate to keep a pump cool. This is the reason fire trucks get wet underneath them as fire fighters turn off all their hoses occasionally and the leak keeps the pump from toasting.
And just for your information motor starting currents are usually more like 8x running current not 2 or 3x.
And welcome to Eng Tips mladenf.
Keith Cress
Starting low specific speed pumps against closed valve is almost always recommended. This is typically done to reduce the sudden shocks to the system - think transients. Power at zero head is not a big deal usually as it is much lower than running horsepower at rated conditions. If mechanical seals are specified, then the shaft deflection at the stuffing box should be carefully calculated not to exceed 2 mils (typical design criteria for mechanical seals).
For high specified speed pumps - typically 7000 and higher - the power at shutoff head (zero flow) starts to rise higher than rated power. At even higher speeds, pressure rise and power rise at shutoff is dangerously high - particularly so for axial flow pumps. For this reason, you will not see a closed valve on a very low head, high flow pumps - think storm water pumps here - New Orleans, Southern Florida, Houston, etc.
In water distribution systems, specific speeds are usually between 2000 and 4000 and starting these pumps against a closed valve which takes anywhere from two to eight minutes is VERY common.
A worthwhile comment imo. For op, see FAQ237-1543: How does hp change with flow for a "centrifugal pump"
(2B)+(2B)' ?
That link is confusing. "Opening up on a system throttle", and "adjusting flow in the direction towards BEP". Sounds like double negatives to me. For a straight centrifugal pump I would have said "closing down on the throttle valve will decrease BHP and current draw", which is not the case with axial and mixed flow impellers.
Accordingly, the instantaneous relay settings can be determined for a given motor without considering the fluid lineup. The overload relay settings do consider the fluid lineup.
The link is my FAQ, so I'm always interested in comments that might improve it. But I think you're missing some context in your quotes.
"Opening up on a system throttle valve". The word throttle is used as an adjective indicating the normal function of the valve (we could almost drop the word throttle, but at least it clarifies we're not talking about a recirc valve). Opening is a tense of the relevant verb. It does not seem ambiguous to me.
In a completely different sentence, I said "for mixed flow centrifugal pump, the curve is non-monotonic. As a very rough thumbrule peak BHP is near BEP so current increases when adjusting flow in a direction toward BEP.". What I was saying is that it's not as simple to estimate which direction to change flow to increase BHP on a mixed flow pump as it was on a radial or axial flow pump, but (as a very rough thumbrule) the highest BHP tends to occur near BEP.
That particular FAQ has also been controversial for the statement that axial flow pumps and mixed flow pumps are "commonly referred to as "centrifugal pumps"". I am not saying the principle is centrifugal, only that many people (including some textbook and standards authors) lump radial, mixed and axial flow together under the term "centrifugal". Likewise I observe plant personnel often do not differentiate these types of pumps. But even though some people may refer to them all by the same name, there are differences that become important when you are trying to talk about expected bhp vs flow characteristic. The very fact that the common terminology does not match what an engineer might conclude considering the pump principles is a good reason to mention the terminology imo.
If anything, maybe I should enhance the standard caveats - consult manufacturer's curve for your specific pump rather than relying on these generalities. I also agree my FAQ is now confusing since the 3rd party link that I provided is now broken. Graphs would be nice, along with a label "typical"
(2B)+(2B)' ?
"The link is my FAQ, so I'm always interested in comments that might improve it."
A small point for clarification:
"Multi-stage pumps are typically mixed flow design".
This could do with some clarification, high flow multistage pumps can be mixed or partially mixed flow design, whereas low flow high head multistage pumps would be radial flow.
How about, multistage pumps can be either mixed flow or radial flow with applicable power demands.
It is quite easy for systems to have a pump operating at or beyond end of curve conditions for a short while as the flow rate starts very high against not much back pressure which then climbs as the system starts up. End of curve operations leads to high vibrations, high current and pumps tripping before they have really got going.
More of an issue in long pipelines or where pipes have been drained, but starting against a closed valve allows for a slow opening of the discharge valve and essentially some throttling of the flow once it opens.
There is also a bit of SOP here - what individuals and companies get used to doing perpetuates as no one wants to change something that works for them....
(2B)+(2B)' ?
Keith Cress
Mc Nally Institute Link
i have a question about centrifugal pump with electric motor.
i reduced the pump's impeller to set it to my desired flow rate and head.calculation shows pump's absorbed power in about half of installed electric motors power.i cant re please electric motor.
now question is :in this condition the pump will get correct head and flow rate?(by assuming calculation is correct)
thanks in advance.
Also some numbers and data would help.
I'm waiting for your new post, but please spell check it first.
But in essence the answer is yes, but needs some data to confirm.
