Contact US
What are[img https://res.cloudinary
What are the reasons of the cracking happened in the welding joints of the bottom plate related to the condensate storage tank ? as shown in the photos attached
RE: What are[img https://res.cloudinary
A good example of Corrosion. It may be caused by the material defect, chemical, coating failure, or a combination of above.
Hope to have more detail info as regards.
How old is the tank and when was the last internal inspection ?
What is the history of the types of liquids that have been stored in this tank ...??
Tank bottoms are replaced all of the time ....
MJCronin
Sr. Process Engineer
Condensate is water or hydrocarbon?
Preferential weld corrosion can occur due to the material being affected by the heat or the weld material being different.
It can be quite startling to see at times and any acid or corrosive water can cause this. You need a metallurgist.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
