GT + water WHB
GT + water WHB
Hi everyone,
do you know if it is possible to use waste heat from open cycle gas turbine in a recovery boiler, instead of steam producing water (probably for district heating, that is max 130 deg C at about 8 bar). The expected nominal power of the gas turbine is 22 MW, and heat recovered from flue gas to water 30 MW. Is this system possible to work properly? Do you know any reference plants where this configuration (GT + water WHB) is installed? Thank you in advance for help.
Regards, Pederator
Regards, Pederator
RE: GT + water WHB
I can't swear as to the numbers you quote, but not only is this type of configuration possible, it has been done successfully almost too many times to count; search "Combined Heat and Power" on line.
CR
RE: GT + water WHB
RE: GT + water WHB
RE: GT + water WHB
RE: GT + water WHB
Or are you talking about a different way to use the waste heat? You said "instead of steam producing water", so I may have misunderstood your question.
