Contact US
Identify plug valve manurfacturer
RE: Identify plug valve manurfacturer
Nordstrom ?????(now Flowserve)
It does not appear from my research that Nordstrom ever manufactured small, 1/2" threaded lubricated plug valves. I am thinking it is a company that used to exist but has since been purchased by another company after the above valve was manufactured.
I also think this is Nordstrom..
Seems like a very old valve. It is not mandatory for valve manufacturer to put all of its portfolio into their website, and digitalization only begin effectively for public consumption started in early 2000.
For the last 25++ years, there were so many manufacturers acquired by 'bigger' companies and some product have been removed ever since (sometimes even look like it never exist).
It is quite normal for bigger valve (read: bigger space to print the brand) to incorporate full brand name. For instance "Malbranque". But for some relatively smaller body, I often see "M" on the body. Same logic for other brand as well.
I don't know what you're looking for based on the information. Old lubricated (before 1990s) Plug valves usually Audco, Nordstrom and some others.
Standard plug valve have bore circa 70% area of its full bore, and this applies for most brands.
Suggest to replace with similar design yet in new brand or product rather than try to fix or engineer what you have at the moment. It would be cheaper.
MR
https://nosuchvalve.com
All valves will last for years, except the ones that were poorly manufactured; are still wrongly operated and or were wrongly selected
http://www.eng-tips.com/faqs.cfm?&rat1=2&f...
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
