The Doc say: <OutAttribute> [b]ByRef[/b] item_type As String How to declare this in vb
Hi
please help understand the uf_ref doc.
the doc say:
<OutAttribute> ByRef item_type As String
how I declare this in vb journal ==>> ( Dim ByRef item_type As String ) ?
Because ==>> Dim item_type As String this not work.
CODE -->
UFClone.AskItemType Method
Wrapper method for UF_CLONE_ask_item_type
Public Sub AskItemType (
	input_part_name As String,
CODE -->
   Dim item_type As String  <<== Not works
   Dim s As Session = Session.GetSession()
   Dim ufs As UFSession = UFSession.GetUFSession
   Dim input_part_name As String
   Dim ByRef item_type As String    <<== (ByRef) Do this possible
  ufs.clone.AskItemType(input_part_name, item_type)
RE: The Doc say: <OutAttribute> [b]ByRef[/b] item_type As String How to declare this in vb
Shortly
This throw compile error keyword not valid
and this not work
( Return item_type = null <<== ufs.clone.AskItemType(input_part_name, item_type) )
Thank you.
The "OutAttribute ByRef" just means that the method you are calling is going to modify the value of that variable; it will essentially become the output of the method. You declare the variable normally, but note that its value will be modified by the method.
CODE
Dim input_part_name As String = "some input part name"
Dim item_type As String = ""
After the code runs, the "item_type" variable will contain the item type of the given input part.
www.nxjournaling.com
Cowski
I'm very much thank you
Because I have understood and did as you posted.
But askitemtype (current clone operation part name, part item type) in my journal
Iteration always return null.
The assembly that I iterated have some items types.
Please can you give me a clue why so.
I'm very much thank you.
The doc says if the item type is null ("Empty String") default behavior will be applied.
Suresh
www.technisites.com.au
Hi ufsure and thank you.
Yes I know that.
So
What happened if I remove the
This statement
ufs.Clone.SetDefItemType("")
Then what will the default.
My clone operation is clone some components
And retain the rest.
And for them I set the above default
Statement.
Another question
If I have this
And I use also this
ufs.Clone.SetItemType("some type")
Is this statement do nothing
Because of the previous statement.
Hi ufsure.
After rereading the doc
And deeply thinking
I come to feel that you are right.
Tomorrow I will have access to nxmanager
And I will test it.
Because immediately after the statement
Nx set all the parts in the clone operation
To item type null.
And when I asked the item type for
A part i get null and that makes
My journal to go wrong.
Hi
I'm disappointed.
I removed ufs.Clone.SetDefItemType("")
From my journal.
and still I got null in askitemtype
Do someone have a thought about
This.
Why askitemtype always return null.
Thanks in advanced.
Can you post the complete code and let me know what you are trying to clone?
Suresh
Hi ufsure and thank you for your wanting to help me.
'The code wrote in my company and I can not bring it out from company. (restriction issue)
'but this is the relevent recoded for the problem issue
Dim pnItemType As String = Nothing
Dim addAssemblyPart As String = Nothing
ufs.Clone.Terminate()
ufs.Clone.Initialise(UFClone.OperationClass.CloneOperation)
Dim status As UFPart.LoadStatus = Nothing
ufs.Clone.SetDefFolder(":Cloned Parts")
'ufs.Clone.SetDefItemType("") ' with / without this still return nothing
'ufs.Clone.SetDefItemType("som_string") ' I tryied this and still return nothing
addAssemblyPart = "@DB/" & display_part.FullPath
ufs.Clone.AddAssembly(addAssemblyPart , status)
ufs.Clone.SetDefAction(UFClone.Action.Retain)
ufs.Clone.SetLogfile("c:\clone_log_file.txt")
ufs.Clone.StartIteration()
Do
ufs.Clone.Iterate(prt_name)
If(prt_name = Nothing) Then Continue Do
If prt_name.Contains("/specification/") Then Continue Do
ufs.Clone.AskItemType(prt_name, pnItemType) ' this alwaisreturn nothing
If pnItemType = "UserPart" Then
ufs.Clone.SetItemType(prt_name, "UserPart")
else
ufs.Clone.SetItemType(prt_name, "ExtPart")
End If
Loop While (prt_name <> Nothing)
Dim faile As UFClone.NamingFailures = Nothing
Try
ufs.Clone.PerformClone(faile)
Catch e As Exception
lw.WriteFullLine("NX Exception = " & e.ToString)
End Try
'I replaced these statements:
else
End If
'by this statements:
'To check if SetItemType works and indeed works
CODE -->
   Do
     else
     End If
   Try
   End Try
   else
   End If
Note that the complete journal
Works as expected.
Except that it's recording the wrong
Item type. ( Not the one I want )
Sorry, please contact GTAC for help.
Suresh
I'm thank both
For training to help me.
I'm thank both
For trying to help me.
I'm thank both of you.
Sorry ny English
Is not my first language.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Considerations for choosing a 3D printing technology
The adoption of 3D printing into major companies’ product development life cycles is a testament to the technology’s incredible benefits to consumers, designers, engineers and manufacturers. While traditional production methods have limitations in manufacturability, 3D printing provides unparalleled design freedom due to the additive method of building parts layer by layer. Download Now
White Paper - Are all 3D printed metals the same?
With so many different 3D printing metal systems and processes today, how can you know exactly what you’re getting? Today, there are several different methods for manufacturing 3D printed metal components with their own strengths and limits. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
