WPS/PQR Sharing
WPS/PQR Sharing
WPS/PQR Sharing
Hi Team,
Recently our welding plant in Perth closed & starts operations at another country with new welding machines.
Does the WPS/PQR procedure used at old plant can be transferred to new plant or any other procedure for sharing accordance ASME IX?
Please advise.
** I'm not welding professional.
RE: WPS/PQR Sharing
A new location, under the same ownership and same banner is good to go.
WPSs and supporting PQRs are considered intellectual property. If I purchase company XYZ, their welding documentation becomes my property. I can use them as long as the new company is noted to reflect the change in ownership.
Best regards - Al
RE: WPS/PQR Sharing
If you are manufacturing items to the BPVC with stamping, you will also need to address this in your Code Quality Manual.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
