NX 12 can't move dimensions when in an assembly while trying to edit a active component's sketch
The company I work for upgraded from NX 8.5 to NX 12. At this time our customer defaults and environments needed to be totally redone. I'm hoping there is a setting for this issue. Of which is, when working in assembly, activating only one part and then editing a sketch, dimensions become immovable. You can't drag them they just end up where the second click is made to make the dimension. This is usually in an obscured place and extremely annoying. For the love of all things CAD that is supposed to make the design process smooth and efficient, does anyone know how to fix this?!?!?! I've looked far and wide but can't find anything. PLEASE HELP for my sanity and that of my coworkers. Thanks!
NX 12, windows 10
RE: NX 12 can't move dimensions when in an assembly while trying to edit a active component's sketch
Try rotate the view slightly. We had this weird thing happen and noticed that a slight rotation made the dimensions movable.
I do not think this bug is there in our current version, 12.0.2 MP4. ( See https://www.eng-tips.com/viewthread.cfm?qid=440632 why you should install 12.0.2 MP4 or later.)
What specific version of NX12 is it you are running?
Tomas
I have tested that issue in MP5 and it appears to have been fixed.
Rotating the view works, I don't know why I didn't think of that as it's so obvious that would fix the issue..... I will forward this to my CAD administrator to get the latest version updated. Thanks for the help!
NX 12, windows 10
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper – Data Security and Know-How Protection
Our data is constantly exposed to the danger of being intercepted or stolen as it wends its way over global data networks. Data security measures and measures for protecting intellectual property should not, however, first be implemented when data is exchanged – companies must lay the foundation for these measures within their own organization. Download Now
White Paper – Collaboration in the PLM Context
The influence exerted by the Internet of Things (IoT) means that there is a steadily growing need for collaboration in industry. Partners from new industries and areas of application need to be integrated in cross-company business processes to ensure that the lifecycle of smart, connected products can be managed from end to end. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
