Compressor Disassembly help
I have several hundred compressors with top ends requiring new seals. The problem is: the cup seal is held in place with a compression/interference ring.
I cannot remove this ring with a 3 jaw puller, as there is nothing to grab onto. I've tried heating the ring with propane, but to no avail.
Short of trying to melt the ring in a bucket of acid, and grinding the feet down to knife edges on the 3 jaw puller, I'm at a loss for how to remove the ring in order to replace the worn cup seal...
My goal is to get these things refurbished and back into operation, so minimizing damage to the aluminum piston head is required. (could also use advice on how to press a new ring into place once properly disassembled)
(Edit: the worn cup seal in the photo has been cut away to show the part)
I have attached photos.
Please help!
Ryan
RE: Compressor Disassembly help
don't those rings have slits from which you can pry them out?
What part in this picture are you trying to remove? A drawing would be much more useful to me than a picture.
Johnny Pellin
What does the manufacturer advise???? Is there nothing in the operation / maintenance manuals??
I'm leaning to using a lathe to remove the ring. The replacement can go on with an arbor press and a little anti-galling material.
eBook - Efficient and Effective Production Support with 3D Printed Jigs and Fixtures
Jigs and fixtures offer manufacturers a reliable process for delivering accurate, high-quality outcomes, whether for a specific part or feature, or for consistency across multiples of parts. Although the methodologies and materials for producing jigs and fixtures have evolved beyond the conventional metal tooling of years past, their position as a manufacturing staple remains constant due to the benefits they offer. Download Now
Overcoming Cutting Tool Challenges in Aerospace Machining
Aerospace manufacturing has always been on the cutting edge, from materials to production techniques. However, these two aspects of aerospace machining can conflict, as manufacturers strive to maintain machining efficiency with new materials by using new methods and cutting tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
