NX 1847, Can't delete attribute & roll back to "No Value" status
Ran across this using PLIST_IGNORE_SUBASSEMBLY.
I would traditionally use the following to show or hide a part in the parts list.
1 = Hide
No Value = Show
But now, once you place a value in an attribute, you can't roll it back to No Value.
Even a no entry puts you parts in a Hide status.
You now need to use, in small case
"on" = Show
"off" = Hide
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX11, Win 10 Pro
RE: NX 1847, Can't delete attribute & roll back to "No Value" status
That is interesting, I've had this problem in the initial release of 12 but wrote a grip to delete it since manual manipulation would not unset it, at times. Grip because it was four lines of easy code vs a journal.
I will have to try this next time it happens, thanks.
NX 12.0.1.7 Windows 10
Hmz I got the same thing last week.... I had to remove and add a part to fis it....
Strange things are happening.....
Lars
NX native (NX13 or NX1847)
Solid Edge ST10
Inventor
Solidworks
in nx12 i have resolve this issue
with this workaround : delete the attributre "PLIST_IGNORE_SUBASSEMBLY
from the attribute bulk editor.
to me return the "NO VALUE" field.
Let me know if this work for you.
NX 7.5 64bit
NX 9.0.3.4 MP4 64bit
NX 10.0.3.5 MP3 64bit
www.studiotreccani.com
Yes, it works with bulk editor on NX1847 too.
Suresh
www.technisites.com.au
Yes you can do it in the bulk editor... good find.
Right Click on the field, select "Clear Contents"
Works in V11 & V1847.
Dave
NX11, Win 10 Pro
White Paper – Your Construction ERP RFP Checklist
Selecting business software for a medium to enterprise-sized construction concern is extremely challenging in large part because most enterprise resource planning (ERP) suites originated in the world of repetitive manufacturing and are therefore a poor fit for a project and asset-centric business. However, midsize to large contractors need the predictable, auditable processes that ERP delivers. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
