Making a drop down menu in a Feature dialogue box
Hi guys,
I've trying to make a drop down menu in a "Pull Face" feature.
The objective is to have a M6 screw as a MASTER and with the drop down menu choose the length that I need (from the standarts available) and save it as a new part to use in an assembly.
Is this possible or is there any way of doing something similar?
I'm using NX12.
Thanks in advance,
Marco
RE: Making a drop down menu in a Feature dialogue box
Have a look at PTS (Product Template Studio)
It requires (of course) a license. Other way would be to create code for it.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
Thanks Ronald...
I guess I'll do it some other way ...
Did you try making it a User Defined Feature? That would allow you to alter the length infinitely or select from a specific list of standard lengths.
Hope this helps,
RJ
RJ
NX 12, Teamcenter 11, Windows 10
This is what the Re-Use library is built for.
Screws found in the Machinery Library are Part Families which can be a hassle.
I've scabbed a lot of those fastener parts and turned them into my own re-use parts minus the part families.
They just clone into your assembly and active design folder.
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX11, Win 10 Pro
White Paper – Your Construction ERP RFP Checklist
Selecting business software for a medium to enterprise-sized construction concern is extremely challenging in large part because most enterprise resource planning (ERP) suites originated in the world of repetitive manufacturing and are therefore a poor fit for a project and asset-centric business. However, midsize to large contractors need the predictable, auditable processes that ERP delivers. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
