Contact US
Hydraulic spool valve clearance
For high pressure, directional control valves, I have read that the diametric clearances from spool to bore are generally around .0002"-.0006". I was wondering what this refers to? Would this be both the spool and bore at maximum material condition? Or is that just the clearance based on the size limitations from both, and that concentricity and out of roundness are not included in that .0002"-.0006" clearance?
Thanks in advance.
RE: Hydraulic spool valve clearance
GD&T may not apply.
I have the impression that good high pressure valve spools and sleeves are fitted to each other individually, and are not interchangeable, and that the clearance is damn small.
Mike Halloran
Stratford, CT, USA
Ahhh that would not be ideal. If it makes a difference the assembly I'm concerned with does not have a sleeve, the valve slides directly in the bore in the block, with the bore being either ground, or lapped/honed.
Thank you.
I'd expect that a body that's not circularly symmetrical, would distort enough to bind under temperature changes or stress from external forces, like mounting bolts, if the clearance were small enough to seriously limit internal leakage.
If the clearance is large, i.e. internal leakage is not significant for the application, I guess it would be okay.
Are you working with actual production valves, or just math models?
Mike Halloran
Stratford, CT, USA
Working with actual production valves. Internal leakage would be significant for the application. Temperature of the oil/ambient conditions would be regulated. I am concerned about binding though, it seems like it would take very little to potentially bind up with such small clearances.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
