Blocking of over-current function in GE relay
Hello All,
On a multilin 750, I want to block the second phase instantaneous element. It has an option to block overcurrent function, in the drop down it has different input selections. Based on the attached image:
1. When the voltage is applied/available across the INPUT-1, the contact will open. Is that correct? and the instantaneous element will not be blocked? AND
2. When the voltage is NOT applied/available across the INPUT-1, the contact will be closed. Is that correct? and the instantaneous element will be blocked?
This relay is different than other relays available where the logic can be used to invert the input which makes it easy to interpret.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Functional Prototyping Using Metal 3D Printing
Functional prototypes are a key step in product development – they give engineers a chance to test new ideas and designs while also revealing how the product will stand up to real-world use. And when it comes to functional prototypes, 3D printing is rewriting the rules of what’s possible. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
