Beyond the uncertainty with future excavations, there is the work by O'Neill and Reese for drilled shafts. Their research indicated that the mobilization of skin friction 'shearing' along the sides occurred at much smaller displacements than the end bearing. Therefore, when the full bearing capacity is reached, the side friction has already experienced too much movement to retain its full friction value. There's interaction equations from their work now included in the AASHTO bridge design spec, but we have not bothered to use them since the first time we went through the arduous calculations, only to get a result that gained us almost nothing (we were able to utilize about 5% of the skin friction with the full bearing and vice versa).
You're supposed to ignore skin friction near the bottom anyway (in the case of drilled shafts, 2 diameters), due to the 'downdrag' effect of the bearing load on the surrounding soil. I don't know about how your geotech info was presented, but what we get is adjusted based on the size of the footing to account for that effect.
In short, OG's response of a flat "NO" is correct, but for more reasons than just uncertainty about future conditions.
