EnginerdNate
Aerospace
Hi all,
First post here, let me know if I'm not in the right section.
I'm working on some bolted shear-tension joints. I'm currently planning to use NAS6206 bolts and MS21042 deformed thread lock nuts. This application is my first exposure to this series of fasteners and I have a question regarding clearances between the washer and the head-shank fillet under the fastener head. I did a bunch of searching and found this thread:
In which WKTaylor states that the minimal interference between the small head-shank fillet on these fasteners (The NAS620X series being the reduced thread length non-CRES version of the NAS670X series) and the standard NAS1149 washer is acceptable. That said, the OP never answered WKTaylor's question regarding the calculated interference. Using the worst case scenario, with the washer at 0.380" and the maximum fastener OD and root radius of 0.3745" and 0.025" respectively, I'm calculating a maximum clash of ~0.022" which seems like a lot.
I don't mean to question the conclusion here as much as understand it. In my previous job, we used tension head fasteners with large root radii almost exclusively on the design details I was a part of, primarily MS21250s with MS21299 countersunk washers under the head with NAS1804 nuts + flat washers on the nut side. In my current application I'd like to avoid having separate types of washers under the fastener head and under the nut, because I know they're going to get mixed up during production. So I want to believe the conclusion regarding the NAS1149 washers, but I haven't found any info so far that gives me a "warm fuzzy" about it, other than the single post referenced above. Can anyone else shed more light on this issue?
Cheers and thanks,
Nathan
Cheers and thanks,
Nathan
