Customize the smart component
Sagrado
Industrial
UA
Accidentally stumbled upon video about using smart components ( )
Interested in the next moment When dragging from a library of designing a minifix and hacking on the
model the author does not Specifies no parameters (ie at what depth they should be, and that they should be exactly in
the middle of the thickness of the plate)
Maybe someone can tell you how to do it I will be very grateful
Sagrado,
Your video is about an IKEA cabinet. IKEA's stuff is highly standardized. They use a standard thickness of MDF. The screws and dowels are standard. That funny cylindrical thing is a casting I think. There is one version only.
As designer, we can place holes with standard diameters and depths for these fittings. Only the positions of the holes need to be parametric. It should not be difficult for IKEA to add holes for their fittings to the hole wizard, and to have standard tools out in the fabrication shop to cut the holes.
JHG
Customizing your design components library in Solidworks is a fairly straightforward and easy thing to do. There are tutorials. To reference drawoh's comment, yes, the cylindrical quarter-turn fastener receptacles are diecast zinc alloy.
