Specialist tap / die
Hi all,
I'm working on a current project whereby I need to find or make a tap that can connect the Knuckle Thread DIN 168 especially for glass containers (male) to a tapped nylon / steel with the correct counterpart.
I've searched all over for a conversion from Knuckle Thread DIN 168 (GL) range to any other type but I can't find anything suitable. Does anyone here know of any reliable specialist thread producers or someone who could help?
This is my source for thread info — https://www.gewinde-normen.de/en/knuckle-thread-di...
The ultimate goal is to be able to connect glass forms with GL thread to a metal arm, threading the glass on and off whenever needed.
Any leads would be greatly appreciated!
D
D
RE: Specialist tap / die
I expect most users of these threads will be machining them out of graphite for EDM of dies rather than using taps.
Either buy a lab thread to tube adapter, such as:
http://shop.llg.de/info1204_Laboratory_threaded_jo...
Or pay a machine shop to single-point-thread your parts to the correct threadform.
I'm designing a lighting system and want to be able to tap the tubing myself and screw the glass in.
I can probably design the glass with a fixture that doesn't require a screw thread but feel this is the most intuitive and reliable for the long term. Any other thoughts on glass connections are much appreciated, thanks!
