Nodes in SAFE? Moment value at a particular point
nanmi
I have few questions for SAFE:
1. I have set Maximum bar preference to 35M bar but on slab detailing it shows 55M bar. I want to know moment value for that point where it shows 55M. (page 2 of attached file)
2. How can I get maximum moment and axial force on a particular point. When I print table it shows Area element and nodes, but how can I locate those points on plan? There is no nodes label option to view. (page 1 of attached file)
3. How can I see a moment and shear diagram in a particular strip, Is there any command to see it?
Please reply.
 https://files.engineering.com/getfile.aspx?folder=48f717e0-0136-4b3b-acd8-fbd29c39f6ab&file=5.pdf
1)This seems to be detailing, i dont use it, but parameters could be wrong
2)You are looking at nodal stresses. Trying to figure out this from tables have not really practical application, and will be a hectic unnecessary task . Why dont you display stress contours, and locate maximum and minimums?, this is how is usually done.
3) Display>Show strip forces. But you need to have strips drawn.
