Paste special(as result with link) in catia VB
thread560-366800: Paste special in catvbs
Hello People,
Im new to catia Vb and i m trying to automate a process in catia,I'am trying to write a catia vb program for Paste Special(as result with link) published bodies from 1 part to another can any one Help!
I need to learn VB for this, i need some materials to start can one share what they have or know?
Thank you
glassesbigears
RE: Paste special(as result with link) in catia VB
I need to learn vb to create macros.
i didn't go like that, i just start to make macros in vb i didn't have any knowledge about it. Just simple interface one or two buttons and so on.
Vb is kinda easy to learn, catia macro is more advanced, once you figure macros Vb will help you a lot. I will recommend everyone to use vb, because it much easier to make good macro.
If you don't know macros, you can start on this forum or on my website.
you can check this post also
https://www.eng-tips.com/viewthread.cfm?qid=447741
you can check this post for your problem
http://www.scripting4v5.com/how-to-pastespecial-wi...
Also i will write some post on my website on this topic.
All the best
Thank you bigsmile
eBook - Mastering Tolerances for Machined Parts
When making CNC machined parts, mastering tolerances can be challenging. Are general tolerances good enough? When does it make sense to call out for tighter tolerances? Do you need a better understanding of fits, datums, or GD&T? Learn about these topics and more in Xometry's new e-book. Download Now
eBook – How to Choose the Correct Corrosion Testing Method
When designing a metal component, engineers have to consider how susceptible certain alloys are to corrosion in the final product’s operating environment. In a recent study by NACE (National Association of Corrosion Engineers), it was estimated that the direct and indirect costs of corrosion in the United States is approximately 6.2% of the GDP. In 2016, that cost exceeded $1 trillion dollars for the first time. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
